JD 4010 Compact won't start after snow plowing
   / JD 4010 Compact won't start after snow plowing
Yeow ! the same thing happened this AM !!! Ran beautiful yesterday and today same thing. Went below freezing last night but in the 40's right now and nothing. Thanks for the tip on block heater. Hope I don't have a bad switch that will act up now and then.
   / JD 4010 Compact won't start after snow plowing #22
Block heaters are nice but a tarp and a a 1500 watt heater will work just as well if not better as the whole tractor gets warmed. It should only take an hour or so.:)
Thanks. Since I don't have a block heater on hand, will use the tarp and hearer again tonight. Thanks to all. Keep you informed
To all who helped me 2 yrs ago. A big thanks !!!! Had same problem this year (no snow last yr). Called JD and they said sounds like seat switch. Unhooked it and then re-hooked up and it ran great. Mia cuppa ! Switch was bent and misshaped because when I run PTO from the ground I stick a screw driver in the button. Been doing it for years. Payed the price. Thanks again. Why are learned lessons so expensive ? Bruky
2012 BIG TEX PIPE TRAILER (A58214)
2012 BIG TEX PIPE...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2019 INTERNATIONAL...
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A57192)
2001 WELLS CARGO...
2014 GMC Sierra SLT Crew Cab Pickup Truck (A59230)
2014 GMC Sierra...
DEUTZ MARATHON...
2015 Ford F-250 Crew Cab Pickup Truck (A59230)
2015 Ford F-250...
