JD 4010 Compact won't start after snow plowing
/ JD 4010 Compact won't start after snow plowing #1
Bruky
Fostrer RI
4010 Compact
After moving a zillion tons of snow yesterday (Sat) after Blizzard. Parked my JD 4010 compact in its unheated shed. Temp. went down to 9 degrees. This AM (Sun) turning the ignition key produced a slight click. All the dash lights go on and the headlight come on and DO NOT dim when I try to start.
Am I dealing with something frozen or is it more serious? Any help would be appreciated.
/ JD 4010 Compact won't start after snow plowing #2
Start with the basics that you forget when it's cold? Any safety not activated like being in neutral, seat disconnect, anything like that. I had a similar situation during a big storm. Went crazy when Ford 1710 wouldn't start. Turns out it was in gear the whole time.
Took a warm-up and cup of coffee to figure it out. Hope it turns out to be that easy.
/ JD 4010 Compact won't start after snow plowing #3
How is the antifreeze is it iced up in the radiator and block? Engine oil heater on that machine? Like Buzzard said sometimes the simple things first like PTO lever, or in gear. Ice might have melted then refroze on one of the levers and switches.
Thanks BuzzardA91, tried those basics. The speed indicator lever (must be in N to start) seemed a bit stiff this AM but now, noon time, it seems more loose. Looked for disconnected wires but found none.
Well Treemonkey, I do believe you're right on. I feel there is ice some place but where? Radiator looks OK. No heater and shed has no electricity. Heard that starters can get wet and then freeze up. True ?
/ JD 4010 Compact won't start after snow plowing #6
You might try the old trick of rapping on the starter with a hammer in that case don't beat it into a pulp though. That might unstick the bendix if that is the case. You don't have any portable heaters around to put under or near the tractor motor and linkage to thaw it out a bit do you? I have put a kerosene heater near the motor then plywood over it to direct the heat in the past when I had my tractor. Or you might even take the battery out bring it inside to warm it up a bit. 9 degrees is too cotton pickin cold for this Treemonkey
I figured out how to get power out there and will put a small space heater next to the starter. It might get to 40 today but that's only an maybe. Thanks for the help. PS Afraid to rap the sucker because at this point it would feel so good to use my 20lb sledge ! Thanks again
Thanks Egon, will be able to get power there and try a space heater. Will let you know if it worked. Being from NS, you must have some neat tricks to avoiding this in the future. Would love to hear them.
/ JD 4010 Compact won't start after snow plowing #10
Surely do wish I had a bag of tricks.:(
Throw a tarp over the tractor also and hook up a battery charger. That will help get the whole thing warmed up.:)
Think about making a battery maintainer a permanent set up.
Then check out all the switches etc. and battery posts. Check fuses and remove reinstall relays. Use some dielectric grease on them. Heat gun can come in handy when doing this but don't melt the plastics.
Wife's hair dryer would also work but make sure the shed has enough room for a cot and one of them -30 C rated sleeping bags.
Note: I never follow my own advice??:D
Thanks. Will try the battery charger right now. As for the cot in the shed. Let's not give my wife any ideas.:cool2:
/ JD 4010 Compact won't start after snow plowing #12
When you say you hear a slight click is that from the starter solenoid or just your glow plug timer switching out. What does the battery voltage read?
/ JD 4010 Compact won't start after snow plowing #13
If you turn the key and nothing happens, not even the dimming of dash lights, I do not think its the starter being frozen. If it was frozen you would think there would be a high current draw as the starter is trying to turn which would then cause the lights to dim. I'm thinking it is a saftey switch, maybe the seat or the pto switch for the mower. Sounds light something has froze up or got moved be accident. If you turn the key, you should here a click of the soleniod for the starter, if that's not happenning it's got to be in the safety curcuit. :2cents:
It started !! thanks to all that tried to help (even non JD owners). Out temperature moderated and I put a space heater close to the starter. If it was a frozen starter, bendix or safety switch, something thawed and it started and now I can finish plowing. Oh joy, oh joy. How can I keep this from happening again. It has never happened before. Will idling the engine 10 or 15 min after I finish plowing sort of dry things out ?
Again, thank you all for the help.
/ JD 4010 Compact won't start after snow plowing #17
:thumbsup:
Until you know what it was you won't know to prevent it again. If something was frozen that's easy. Or maybe it just fixed itself? Happened to me before on plenty of things. Glad to hear.
/ JD 4010 Compact won't start after snow plowing #18
Good to hear it's running.:thumbsup:
Running for a bit after the snow work is over won't hurt anything. Go over all the connections, clean & grease them.
Thanks again. Happened to run into a JD mech and he said it in not uncommon for the safety switches to freeze up from plowing. Like Egon said, "clean and grease" and also WD 40. Gotta go and finish plowing.
/ JD 4010 Compact won't start after snow plowing #20
As an after thought I would get some power to the shed even if it is with an extension cord. Then put a block heater on the tractor or any other type of heater to keep your little baby warm.
