JD 4000 Series Availability Problems
   / JD 4000 Series Availability Problems #1
dmize
va
Mahindra 4035 HST
I was intersted in looking at some 4000 series tractors, but the local dealership chain said they aren't in production and the only way they can get one is to order it. Well, that doesn't really work for me, plus it means I will be paying a premium because it's not on the lot.
So is anyone else having trouble finding a 4000 series to test drive?
   / JD 4000 Series Availability Problems #2
So is anyone else having trouble finding a 4000 series to test drive?[/QUOTE
Can't blame you for wanting to see before you buy. I differ with the opinion that you will be paying a premium because it is not on the lot. I would consider the ordered tractor with a small deposit a safer bet for the dealership and would expect about 18% off list on your order.
   / JD 4000 Series Availability Problems #3
Today I was inquiring about the new 4 series. I was told that if you want a 4720 that they are no longer making them however if you wanted a 4520 you could still order it. This was in Ontario, Canada so it should be the same in the States as well.
   / JD 4000 Series Availability Problems #4
I believe JD is no longer building any of the 4020 series tractors.
They do still have many in inventory at the factory lot.
Great information, thank you all for the help.
2022 RAM 2500 (A50854)
2014 KENWORTH T800 SLEEPER CAB (A50854)
2014 KENWORTH T800...
1984 AM GENERAL HMMWV HUMVEE (A51222)
1984 AM GENERAL...
MAXUM M-1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM M-1000...
2018 Skyjack SJ1056TH 10,000lb 4x4 Rough Terrain Telehandler (A49461)
2018 Skyjack...
2013 John Deere 544K Articulated Wheel Loader (A50322)
2013 John Deere...
