JD 4000 Series Availability Problems
   / JD 4000 Series Availability Problems #1
dmize
Member
va
Mahindra 4035 HST
I was intersted in looking at some 4000 series tractors, but the local dealership chain said they aren't in production and the only way they can get one is to order it. Well, that doesn't really work for me, plus it means I will be paying a premium because it's not on the lot.
So is anyone else having trouble finding a 4000 series to test drive?
   / JD 4000 Series Availability Problems #2
So is anyone else having trouble finding a 4000 series to test drive?[/QUOTE
Can't blame you for wanting to see before you buy. I differ with the opinion that you will be paying a premium because it is not on the lot. I would consider the ordered tractor with a small deposit a safer bet for the dealership and would expect about 18% off list on your order.
   / JD 4000 Series Availability Problems #3
Today I was inquiring about the new 4 series. I was told that if you want a 4720 that they are no longer making them however if you wanted a 4520 you could still order it. This was in Ontario, Canada so it should be the same in the States as well.
   / JD 4000 Series Availability Problems #4
I believe JD is no longer building any of the 4020 series tractors.
They do still have many in inventory at the factory lot.
Great information, thank you all for the help.
2006 Peterbilt 379 T/A Wet Kit Sleeper Cab Truck Tractor (A49461)
2006 Peterbilt 379...
Ih 1066 Tractor (A50514)
Ih 1066 Tractor...
2012 MAXEY TRAILER MFG 100KW GENERATOR TRAILER (A50854)
2012 MAXEY TRAILER...
2007 John Deere TX 4x2 Utility Gator (A49346)
2007 John Deere TX...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A49461)
2009 Trail King...
2011 BMW 5 Series 550I GT Sedan (A50324)
2011 BMW 5 Series...
