JD 400 Hydro
/ JD 400 Hydro #1
terranceb
Beach Park, IL
John Deere 400/ John Deere x534
Have JD 400 garden tractor. Have to constantly regulate speed w/ ground control lever. Is hydrostatic shot or can it be repaired/adjusted?
/ JD 400 Hydro #2
By having to constantly adjust the speed are you talking about traveling on level ground and speed varies or going up and down hills?
Does the speed lever move easily or is there some friction / force required to move this?
/ JD 400 Hydro #3
I believe there is a shock attached to the speed control lever. If it is bad I know the speed will be erratic. Also make sure the linkage is tight and there is no play were it hooks to the trans. I have seen the hole in the lever were it attaches to the trans worn out.
/ JD 400 Hydro
oldnslo. you're probably younger and faster than I. Up and down hills requires constant travel speed adjustments. Some friction in lever. Force to move lever seems same as it's been for some time. Several years ago lever had more resistance.
/ JD 400 Hydro
JD420. Thank you for the insight on the linkage. I will get my nose into it at my first opportunity. Repowered 400 with B&S Vanguard last year. Getting hydro back to good will make for a honey of a tractor/
Volvo EC55B Exvacator (A62679)
Volvo EC55B...
60in Bucket Skid Steer Attachment (A61567)
60in Bucket Skid...
2004 John Deere 4710 Sprayer (A63688)
2004 John Deere...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01120 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
New/Unused Wolverine 84in Dozer Blade/Snow Pusher (A65583)
New/Unused...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
