JD 400 Hydro
/ JD 400 Hydro #1
terranceb
Beach Park, IL
John Deere 400/ John Deere x534
Have JD 400 garden tractor. Have to constantly regulate speed w/ ground control lever. Is hydrostatic shot or can it be repaired/adjusted?
/ JD 400 Hydro #2
By having to constantly adjust the speed are you talking about traveling on level ground and speed varies or going up and down hills?
Does the speed lever move easily or is there some friction / force required to move this?
/ JD 400 Hydro #3
I believe there is a shock attached to the speed control lever. If it is bad I know the speed will be erratic. Also make sure the linkage is tight and there is no play were it hooks to the trans. I have seen the hole in the lever were it attaches to the trans worn out.
/ JD 400 Hydro
oldnslo. you're probably younger and faster than I. Up and down hills requires constant travel speed adjustments. Some friction in lever. Force to move lever seems same as it's been for some time. Several years ago lever had more resistance.
/ JD 400 Hydro
JD420. Thank you for the insight on the linkage. I will get my nose into it at my first opportunity. Repowered 400 with B&S Vanguard last year. Getting hydro back to good will make for a honey of a tractor/
2004 IH 5600I Snow Plow Truck (A62679)
2004 IH 5600I Snow...
2017 Ford E-Series FedEx Delivery Truck, 5.4L V8, Step Van Conversion (A63689)
2017 Ford E-Series...
2018 Holbart 210 MVP Mig Welder (A64194)
2018 Holbart 210...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
JOHN DEERE 220 - 18' DISC HARROW (A64277)
JOHN DEERE 220 -...
