JD 4 in 1 bucket problem
   / JD 4 in 1 bucket problem #1
Cidertom
Benton Co Oregon
JD 4520, 2305 Aktive snow-trac ST4
Equipment: 400CX FEL with a JD 4 in 1 bucket.
Problem: During use, the lower cylinder pivot area fills with debris packing in around the hydraulic fitting, causing the fitting to break.
Discussion: Had one break, had one damaged. Thinking about some sort of guard that will hinge to allow access to grease zerk but not allow debris to pile up under the cylinder. A rubber (old truck inner tube) around the top to keep stuff from falling behind.
Anyone had similar problem? Any solutions already out there?
   / JD 4 in 1 bucket problem #2
How old is the bucket?
bought first of 2006
   / JD 4 in 1 bucket problem #5
I have a 6 yr old 4 in 1 bucket and have had not probs.but the bottom of where you are having probs. is a open bottom on mine bucket yours has closed bottom. I have two ideas.first,hole saw a hole in the bottom of the plate to let the dirt out.Next,take the cydliner out and put a piece of soft foamin the space where the dirt is packing,Good luck.
minimax
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A56438)
2-Row Peanut...
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
2010 Deere 318D (A60462)
2010 Deere 318D...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2019 Ford F-150...
2009 Kubota M108S (A60462)
2009 Kubota M108S...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
