JD 4-in-1 bucket grease zerks
   / JD 4-in-1 bucket grease zerks #1
zuiko
Platinum Member
Minnesota
JD 990 4WD
My bottom zerks disappeared... anyone know off hand what size these are? Are they metric or SAE?
   / JD 4-in-1 bucket grease zerks #2
If you bought the 4 in 1 from Deere, contact your dealer. If you bought it aftermarket, contact the manufacturer.
Odds are they're 1/8 NPT fittings. Seems like most are, but that's not necessarily the case.
You can buy zerks at many hardware stores or from McMaster-Carr (online). Always a good idea to have some spares around.
BTW, did they come out or did they shear off?
   / JD 4-in-1 bucket grease zerks #3
Pretty sure they are 1/8" NPT...if they haven't been sheared off your in luck...you can find them at any hardware or auto parts store. Use a little medium strength Loctite when you reinstall them.
Thanks. I just hope the threads are still OK. They seem to still be there (and nothing is broken off in the hole) but I guess I'll find out when I get some new ones and put them in. No idea what happened to them... just went to grease them and I had mud filled holes instead of zerks.
KUBOTA M6800 UTILITY SPECIAL TRACTOR (A51406)
KUBOTA M6800...
2017 TRAILSTART 40FT DUMP TRAILER (A54607)
2017 TRAILSTART...
2015 International 4400 SBA Gap Vac Truck (A53117)
2015 International...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
2007 Yamaha Rhino 660 (A55218)
2007 Yamaha Rhino...
Bell B30E (A50123)
Bell B30E (A50123)
