JD 4-in-1 bucket grease zerks
   / JD 4-in-1 bucket grease zerks #1
zuiko
Platinum Member
Minnesota
JD 990 4WD
My bottom zerks disappeared... anyone know off hand what size these are? Are they metric or SAE?
   / JD 4-in-1 bucket grease zerks #2
If you bought the 4 in 1 from Deere, contact your dealer. If you bought it aftermarket, contact the manufacturer.
Odds are they're 1/8 NPT fittings. Seems like most are, but that's not necessarily the case.
You can buy zerks at many hardware stores or from McMaster-Carr (online). Always a good idea to have some spares around.
BTW, did they come out or did they shear off?
   / JD 4-in-1 bucket grease zerks #3
Pretty sure they are 1/8" NPT...if they haven't been sheared off your in luck...you can find them at any hardware or auto parts store. Use a little medium strength Loctite when you reinstall them.
Thanks. I just hope the threads are still OK. They seem to still be there (and nothing is broken off in the hole) but I guess I'll find out when I get some new ones and put them in. No idea what happened to them... just went to grease them and I had mud filled holes instead of zerks.
2015 CATERPILLAR 930K WHEEL LOADER (A51406)
2015 CATERPILLAR...
Freighliner Tender Truck (A55301)
Freighliner Tender...
Manac Walking Floor Trailer (A50322)
Manac Walking...
2018 JCB 507-42 7,000lbs Rough Terrain Telehandler (A53421)
2018 JCB 507-42...
2014 Peterbilt 337 IMT 10,000LB 5 Ton Crane Mechanics Service Truck (A55788)
2014 Peterbilt 337...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
