JD 3720 Noisy Hydraulics
/ JD 3720 Noisy Hydraulics #1
TC33DA
North Carolina
I needed to move some dirt and gravel the other day and noticed my hydraulics were noiser than normal. The outside temperature was in the 40's so it was cold. I let her warm up for 10 minutes and the engine temp was normal. When I raised the FEL the hydrualics were noisy almost a winning noise. Same from the the 3 pt when I raised the box blade. No issues when moving the tractor. It is a hydro. I know the hydra fluid is thick when cold but thought it should have warmed up. Maybe not since I did not really work it.
/ JD 3720 Noisy Hydraulics #2
Did it quiet down after using the FEL for a few minutes? If yes it was probably the cooler oil. Since the tranny is HST the charge pump helps warm it but this heat is not transfered to the FEL circuit until you start operating it.
Roy
FEL was still noisy after running the system. Talked to dealer and he said the "screen" before the pump might be dirty. Only has 100 hours so it is in warranty. Headed to shop after holidays.
2021 CATERPILLAR 259D3 SKID STEER (A62129)
2021 CATERPILLAR...
2019 Ford F-350 (A55973)
2019 Ford F-350...
2018 Chevrolet Traverse SUV (A60352)
2018 Chevrolet...
2019 TAKEUCHI TL8 SKID STEER (A62129)
2019 TAKEUCHI TL8...
2020 International LT625 Sleeper 48 (A62613)
2020 International...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56858)
2016 AutoHauler...
