JD 3720 Hydraulics
/ JD 3720 Hydraulics #1
Chris P
Wolvengat, RSA
JD 3720
I have a JD3720, awesome little tractor, does what it says on the box, but now I want to do a bit more....
I want to upgrade the hydraulics so that I can fit a trencher onto it, does anyone out there know if this is possible? Or is it going to have to be a PTO drive HPU unit?
/ JD 3720 Hydraulics #2
You have this, so if you build or purchase one, it should work.
Hydraulics:
Type: open center
Capacity: 6.8 gal [25.7 L]
Valves: 5
Pump flow: 8.6 gpm [32.6 lpm]
Total flow: 13.9 gpm [52.6 lpm]
You could also install a PTO pump and run the trencher.
A hyd motor will run on just about any flow. The GPM's will determine the trencher rpm.
Hyd pressure determines the force applied.
Hydraulics:
Type: open center
Valves: 5
Thanks JJ
I am being a bit lazy here for a change and have found a trencher at a reasonable price, but with everything comes compromise.
So the trencher that I found requires between 45 and 80lpm @ between 180 to 240bar, the JD supplies as you have pointed out 32,6lpm @176bar. I had a look at the drawings and see that this is supplied by a geared pump that is what i was trying to find out if it was possible to upgrade. But found out this afternoon, for this flow, I would require a tank of aproximately 200l, so that I don't cook the oil.
So the notion of replacing the pump has gone out the window. So now I will see if I can find a PTO pump that will run the trencher, while still staying within my budget, or I must see if I can replace the motor on the trencher so that it is within the supply spec. but at the same time not compromise the trencher.....
/ JD 3720 Hydraulics #5
200L is 54 gal
I am not so sure you need that kind of volume as most mobile tanks are about 1 to 1.5 of flow to volume, so as to save space and weight.
My machine is all hydraulic with three pumps and 4 wheel motors. My PTO drives hyd motors.
My tank is 20 gal and there is a hyd radiator with a fan.
My engine has the capacity for a 22 GPM pump at 3000 psi.
However, I don't usually use each pumps full potential at the same time, so the load is even less.
2021 Kubota RTV1140 4x4 Diesel Utility Cart (A59228)
2021 Kubota...
Case 950 8 Row Air Planter (A61307)
Case 950 8 Row Air...
1959 DODGE D510 DUALLY FLATBED TRUCK (A59823)
1959 DODGE D510...
2023 JOHN DEERE 85G EXCAVATOR (A59823)
2023 JOHN DEERE...
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
2013 Land Rover Range Rover Sport 4X4 SUV (A55853)
2013 Land Rover...
