JD 350 CRAWLER/LOADER/BACKHOE
/ JD 350 CRAWLER/LOADER/BACKHOE #1
Bill Fortune
Lee, NH
JD 350 crawler loader/hoe
JD 350 CRAWLER LOADER/BACKHOE has Drot (spelling ?) 4-way bucket. Main relief is opening at 800 psi (rated 2250), new hydraulic pump. need main relief valve or a way to repair it. It appears to consist of two pieces, but unable to take them apart. The relief I see in the SM-2063 Service Manual (Jan-1974) is not exactly the one I have.
Tractor S/N; T21358T
/ JD 350 CRAWLER/LOADER/BACKHOE #2
Sounds much more like a hydraulic valve for something is not in the center position is draining off pressure.
Open Center of closed center system...?
Dave m7040
/ JD 350 CRAWLER/LOADER/BACKHOE #3
Bill
Welcome to TBN
My JD industrial equip.knowledge is very limited. Although I will guess a JD 350 crawler has closed-center hyd's I couldn't confirm it. Can you please post a photo of the hyd pump? Keep in mind many hyd pumps have been replaced only to determine original pump wasn't the problem. I would think any 2500# relief valve could be made to work. Original pressure control valve is still available from JD but one needs to check pump pressure 1st. If frt pump is CC then problem could be that stroke control valve in pump isn't seating properly. Has hyd filter been changed lately?
AT18944 Pressure Relief Valve ADD 323.83 USD
It's a "pass through" body, open center valves. I thought that the old pump was having a problem, but the new pump is not any better. I think I see that each or most of the control valves have a relief also. I had to take the bucket off and use it only as a backhoe. I could re-pipe the system so to eliminate the Main Relief, but would lose all control of the bucket boom and dump cylinders.
All valves are held in center. Centering springs are ok.
/ JD 350 CRAWLER/LOADER/BACKHOE #5
Does your 350 have a gear or piston hyd pump?
can't post pictures just yet, have a new "smart" phone that is a pain the system relief is built into the valve body so a plug would have designed. also see my comments to TX JIM
/ JD 350 CRAWLER/LOADER/BACKHOE #7
It will surprise me if 350 crawler has open center hyd's.
OK, I think I see what you are saying. When the valves are in the neutral position then oil is trapped so the cylinders can't move. So I will se if I can find the "circuit relief" valves. Maybe there is a spring in one of them that is broken. Or why can't one of the Anti-cavitation Checks be broken, but if that were the case wouldn't a cylinder move ? Another observation. With the bucket dump cylinders removed from the bucket the pistons don't move in or out (???). I will try again to make sure.
/ JD 350 CRAWLER/LOADER/BACKHOE #9
Bill
Do you understand the differences between closed & open center hyd's? When a hyd control valve is centered no matter if it's CC or OC cylinder should stay in that position if control valve or cylinder aren't leaking internally. What are you referring to as an anti-cavitation check? I sent you a PM
Jim
about all I know about the valves is what I see in the manual dated Feb-67. It shows that when the neutral position the Functional Inlet is under slight pressure. It shows a Check Poppet between the inlets to the cylinders. If I have those Check Poppets then they must on the under side of the valves. I removed the two circuit relief valves and except for the fact they were not real tight, nothing is obviously wrong.
in the diagram the Anti-cavitation Check seems to be ported to the return to the tank and one of the cylinder ports.
I don't see parts manual (PM). is it via this site or email ? indust.consult@rcn.com
Was able to get about 1300 psi.
is that the PM you sent at 6:56 AM ? nothing like what I have. Maybe we should hold up here until I can get to Verizon and determine how to down-load pictures.
/ JD 350 CRAWLER/LOADER/BACKHOE #13
PM=personal message which can be viewed by clicking on alerts(envelope symbol) above.
Ok, got the PM vial email; icon at top of page didn't work. Will call Monday morning or when I can. Have a service call Monday.
Dixie Chopper (A64557)
2013 CASE 580 SUPER N LOADER BACKHOE (A67714)
2013 CASE 580...
2005 FREIGHTLINER FLAT TOP DAY CAB ROAD TRACTOR (A65054)
2005 FREIGHTLINER...
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
2008 SHOP MADE (A67714)
2008 SHOP MADE...
Pemberton Inc 416469 Hydraulic Dual Cylinder Grapple Loader Bucket (A68183)
Pemberton Inc...
