JD-345 Electric problem
/ JD-345 Electric problem #1
leftybob
Barnhart, Missouri
Ford-1100- New Holland 1720 - JD-345- JD-425- Cub Cadet- 1863
I have a 95- JD 345 all electric goes dead. sometimes if I wiggle the connectors at the circut board it will make connection. Is there anyway to check the board. They are not in a good place as they get dirty. I cleaned it once and reconected all plugs and fuses and it worked for about 3 mo. Any idea's?
/ JD-345 Electric problem #2
Without a complete testing of the electrical system and the circuit board it's hard to say, but I can tell you that it would not be the first case of a bad circuit board. IMHO, you're going to have to straight-wire around the board (use an applicable fuse) and test each component or at least a couple. Or test for continuity through the board on each circuit - just one leg/wire at a time - not across them. Lastly, check all grounds and make sure they are good. This should give you a pretty good idea of whether it is the board or not.
Thanks for your reply. It was a ground problem from the battery to engine.
2009 GMC Sierra 2500 HD Pickup Truck (A61573)
2009 GMC Sierra...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A63689)
2008 Ford F-250...
APPROX (50) PIECES OF 10" I-BEAM UP TO 16' (A64280)
APPROX (50) PIECES...
Club Car Electric Golf Cart (A66285)
Club Car Electric...
Landhonor 24" Semi-Automatic Tire Changer (A62679)
Landhonor 24"...
(2) UNUSED 10-16.5 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED 10-16.5...
