JD 336 square baler sheer pin
   / JD 336 square baler sheer pin #11
I am just curious as to why you think they put the slip clutch on the baler. With your reasoning there should only be the shear pin.
Just asking.
   / JD 336 square baler sheer pin #12
I have not had a chance to look at it. When I do I will let you know.
I always thought they put a slip clutch in there because if there is a failure they didn't have to replace a shear bolt, just fix the problem and go on your way.
   / JD 336 square baler sheer pin #13
The shear pin unloads the angular momentun from the right angle drive bevel gears. The slip clutch unloads the tractor's drive torque from the gearbox. Otherwise, you would break gear teeth, fracture the gearbox casting, and/or break the tractor driveline.
   / JD 336 square baler sheer pin #14
Driveshaft powers slip clutch which powers baler while shear bolt only powers flywheel.
   / JD 336 square baler sheer pin #15
To clarify the the slip clutch powers the whole baler as does the shear pin. Shear pin is in place to prevent catastrophic failure in case of something going out of time or a blockage beyond balers capacity.
   / JD 336 square baler sheer pin #16
Sorry but you made an incorrect statement. On JD sq balers since 14T was introduced if slip clutch is stuck or tightened too tight baler one can bale hay with flywheel shear bolt sheared,absent or even with no flywheel. DISCLAIMER: baling hay with FW shear bolt sheared or absent will put undue stress on driveline & tractor pto.
   / JD 336 square baler sheer pin #17
I stand corrected. I am most familiar with new Hollands.
   / JD 336 square baler sheer pin #18
No problem and you're correct NH sq balers drive through shear bolt & slip clutch.
Online Buyers Premium (A55272)
Online Buyers...
UNUSED FUTURE HYD AUGER (A52706)
UNUSED FUTURE HYD...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A57192)
2001 WELLS CARGO...
2019 CATERPILLAR 226D SKID STEER (A52709)
2019 CATERPILLAR...
2012 Chevrolet Van (A55973)
2012 Chevrolet Van...
