JD 3320 SCV Joystick Parts
   / JD 3320 SCV Joystick Parts #1
jbbankshot
John Deere 3320
I am trying to find parts for the joystick toggle switch. The issue I have it my grapple will open and not close. I did a bunch of trouble shooting and determine the the down/close button on my switch is not working. I don't think there is a separate fuse for open vs close. I took the joystick apart and there is a round electronic switch. Is this replaceable? If so, I'm having trouble locating the part number.
Any suggestions would be great!
JB
   / JD 3320 SCV Joystick Parts #2
Yes, the switch membrane is replaceable. First item on the list:
Yes, the switch membrane is replaceable. First item on the list: <img src="http://www.tractorbynet.com/forums/files/john-deere-owning-operating/404427-jd-3320-scv-joystick-parts-joystick-parts-png"/>
It would be great to see a picture, I'll search for that one.
Thanks
JB
   / JD 3320 SCV Joystick Parts #7
I guess I am invisible...good luck.
Everyone was a big help as usual! Now if one of you could make my part instantly arrive at my house, then I could get more work done!
JB
   / JD 3320 SCV Joystick Parts #10
My 4520 did the same thing. It was a broken wire, not the switch itself. The lead broke about half way between the switch and the connector where it rubs on the trim. I replaced the wire with some high quality high strand count wire and re-installed. You might want to do some checks with a multimeter to see if it is the wire or the switch itself. May save you a few dollars.
AGCO Sunflower 20' PT Disc Harrow (A50120)
AGCO Sunflower 20'...
2014 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,400lb 3 Ton Crane Service Truck (A50323)
2014 Ford F-550...
2004 EAST GENESIS TIPPER TRAILER (A52141)
2004 EAST GENESIS...
(30) 9 Box Macro Bins (A50121)
(30) 9 Box Macro...
EZGO GOLF CART (A50323)
EZGO GOLF CART...
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
