JD 3320 question.
/ JD 3320 question. #1
Blee25
Frankfort Ohio
2008 John Deere 5203 fwa loader, 1949 Farmall Cub, 1995ish Craftsman riding mower
I have a 3320 and was wonder how well it would handle moving 1000-1200 pound bales with the 3 point. How much weight would you recommend be added to the front?
thanks
Blee
/ JD 3320 question.
thanks
Blee
/ JD 3320 question. #3
I do that without ANY issues using the loader as the front ballast. My tires are loaded. If you don't have the loader, just get one.
Also, I have R1 tires set full wide.
I have actually had some uncertainty when going down a steep hill during a nighttime deluge. I started t slide, but got out OK...
Bales are widowmakers; proceed with caution!
/ JD 3320 question. #4
/ JD 3320 question. #5
Ballast the front and you will be fine. Loader is the best way. Fill the bucket if you need to.
3pt on the 3320 is 2500+ lbs capable.
/ JD 3320 question. #6
19ft Sailboat w/ 2018 Continental Trailer S/A Boat Trailer (A61574)
19ft Sailboat w/...
2011 Honda Civic Coupe (A61574)
2011 Honda Civic...
(INOP) 2015 BOBCAT S570 SKID STEER (A64280)
(INOP) 2015 BOBCAT...
2015 Freightliner M2 106 Crew Cab Dump Truck (A61573)
2015 Freightliner...
2016 CATERPILLAR 259D SKID STEER (A64279)
2016 CATERPILLAR...
2021 BOBCAT T62 R-SERIES SKID STEER (A64279)
2021 BOBCAT T62...
