jd 332 diesel engine fluxuation
   / jd 332 diesel engine fluxuation #1
fiddleman
Brenham
JD 332
Have a JD332 Yanmar diesel that once cranked up, it will not throttle up when pushing lever up....it stays at an idle. Also when it finally throttles up, it tries to die out when in taller grass or possibly going up a small incline. Please help, need to be using this mower here in southeast Texas with all the rain we've gotten. Any info will help!
   / jd 332 diesel engine fluxuation #2
Fuel starvation or governor, first place to start is the fuel system, clean good fuel, treat the tank for algae and water, check fuel cap vent hole for plugging, check fuel pickups in tank, change fuel filters, check fuel pump, check injectors. Once that is done test it again did problem go away or still the same.
   / jd 332 diesel engine fluxuation #3
Ditto above.
   / jd 332 diesel engine fluxuation #4
fiddle
:welcome: to TBN
Agree, it sounds like fuel related... what of these suggested steps have you covered already?
this was my son's mower, but he did remove tank last year and clean, and has replaced filter. What would you suggest doing to the governor?
   / jd 332 diesel engine fluxuation #6
But you haven't done the other checks yet! Please verify all before proceeding further. The other thing to check is the fuel shutoff solenoid on the engine too.
   / jd 332 diesel engine fluxuation #7
I would suggest leaving the governor alone until you have taken care of EVERY thing else!
Will give it a going over this wknd, thanks for the help/suggestions.
   / jd 332 diesel engine fluxuation #9
Is the fuel pump running? My 332 will start and idle without the pump running and will throttle up if sitting still, but once a load is placed on the engine it bogs and almost dies. Check to make sure the fuel system is providing fuel. The injector pump will draw only a enough fuel to start and idle. It needs the fuel pump running with all of the lines and filter clear to provide enough fuel to operate under any load.
Bill
Bill
will order new inline fuel filter today, no history on how old the present one is. Yes, the pump is running when the key is on. Thanks.
2019 JOHN DEERE XUV855M GATOR (A51243)
2019 JOHN DEERE...
Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
Turfco...
KUBOTA L4630D TRACTOR (A51243)
KUBOTA L4630D...
2007 KOMATSU PC27MR-2 EXCAVATOR (A51242)
2007 KOMATSU...
2012 Volkswagen Jetta (A50324)
2012 Volkswagen...
