Oil & Fuel JD 318 stops running
   / JD 318 stops running #1
Sissybitus
Crossville, TN
John Deere 318; 1987
1987 JD 318 Onan Motor. Will run for 20 minutes, then just shuts down. Wait about 15 minutes and it starts up again and then does the same thing.
   / JD 318 stops running #2
When it shuts down have you checked for spark. maybe the coil is heat failing.
Thank you, I will check for that. I had thought it might be the new gas cap, it didn't have a vent, so I put on a vented cap, but haven't had a chance to test drive.
   / JD 318 stops running #4
It may be related to a capacitor on the ignition circuit.
   / JD 318 stops running #5
All good guesses for symptoms.
- Coil
- Bad tank vent
- Fuel line either getting too hot (vapor lock) and/or
- Fuel line weak enough that it collapses and pinches itself (is this possible?) .
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2015 KUBOTA M5660SU 4X4 FARM TRACTOR (A51243)
2015 KUBOTA...
2012 International 4300 Reefer Truck (A52128)
2012 International...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A51573)
IMPORTANT PLEASE...
2010 Case 650L Crawler Tractor Dozer (A50322)
2010 Case 650L...
Grasshopper 722D Zero Turn Mower (A50514)
Grasshopper 722D...
