JD 317 steering box
   / JD 317 steering box #1
Wheatland KB
Cluny, Wheatland County, Alberta (east of Calgary)
Kubota L3400HST
Does anyone know if there is an adjustment on the John Deere 317 steering box to adjust the play? It is really a PIA when mowing when you have to turn the wheel 3/4 of a turn before the wheels turn.:mad:
I had a 140 years back and it seems to me that there was an adjustment. The steering box on the 317 looks the same but I can't see an adjustment.
   / JD 317 steering box #2
steering gearbox.gif You need to loosen #20 the lock nut on # 19 then turn it in to take up the slack. If it is wore real bad you may need to replace it. Grease up the gearbox real good while your in there.
   / JD 317 steering box #4
Your welcome. Glad I could help.
Piranha P90 Ironworker (A50322)
Piranha P90...
2017 John Deere 6120E 120HP 4WD Agricultural Tractor (A50322)
2017 John Deere...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
Satoh Beaver Tractor (RUNS) (A50774)
Satoh Beaver...
Chemical Tank & Pump (A50121)
Chemical Tank &...
