JD 310E backhoe engine sluggish
   / JD 310E backhoe engine sluggish #1
tractortroof
Jacksonville
kubota b2650
It sat for three months waiting on a cylinder replacement. I think it has been sluggish since getting started up from that rest. Definitely shows its sluggishness when attempting to drag log, lost a good bit of power, almost to the point of sputtering. Is there any good diesel fuel system cleaner I can put in the tank?
   / JD 310E backhoe engine sluggish #2
How old is the fuel filter? Maybe change that first and see if it has any effect. I use Diesel Clean (silver container) in my fuel
Yeah it's likely fuel related, it was off road diesel that was in the tank, sitting for months. I'll try to operate the fuel separator first.
   / JD 310E backhoe engine sluggish #4
Engine sluggishness is likely due to lack of fuel to inj pump not fuel quality. I suggest to change fuel filter & check for good fuel flow from tank to inj pump. My rd baling tractor sat in shed from Oct. '21-last of April '22. Turned ignition key switch engine started went to field & operated rd baler.
It was the filter/separator. Perhaps I could have purged the water out of the first one. I wonder if the off road diesel I got had water in it. Runs like a champ after changing it
2013 Mack GU713 Dump Truck, (A35430)
2013 Mack GU713...
PINTLE HITCH EQUIPMENT TRAILER (A36465)
PINTLE HITCH...
2018 Broce BW260 Ride-On Towable 3 Wheel Sweeper (A35915)
2018 Broce BW260...
35 TON EQUIPMENT TRAILER (A36465)
35 TON EQUIPMENT...
2022 New Holland C327 Skid Steer (A36338)
2022 New Holland...
Unused 14ft x 20ft Single Garage Metal Shed. (A35431)
Unused 14ft x 20ft...
