JD 3038e Loader won't hold curl
   / JD 3038e Loader won't hold curl #11
Its probably the loader control valve. If you pop the QCs for the curl circuit off the valve does it still happen?
   / JD 3038e Loader won't hold curl #12
Pistons might need to be repacked or replaced, have you done any unusually rigorous work with it lately?
It wasn't the cylinders, I had them rebuilt but they said they didn't see any obvious problems. I put them back on and there isn't much difference. It'm thinking it must be in the loader control valve. Does it have any kind of adjustments?
It doesn't have QC but I could unscrew, but wouldn't the hydraulic oil just drain from the cylinders?
   / JD 3038e Loader won't hold curl #15
Yes it would. With quick connects, it would tell you if the problem were in the cylinder or in the valve.
   / JD 3038e Loader won't hold curl #16
Yeah 2. But youve already determined that it isnt the cyls - so no point. If its not drippin on the floor somewhere it is the curl spool in the valve. It will have to be disassembled to fix. JD ought to have a clue about the valve they use / whether fix is feasible.
larry
OK. Thanks for the responses. Now I have a better idea of what to do next.
SHOPBUILT 5' X 13' DBL AXLE TRAILER (A52708)
SHOPBUILT 5' X 13'...
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
New/Unused CFG Industrial MX50R Mini Excavator (A57453)
New/Unused CFG...
2019 Ford F-450 Altec AT200A 30ft Bucket Truck (A56858)
2019 Ford F-450...
2015 LOAD TRAIL 24+6 GOOSENECK TRAILER (A58216)
2015 LOAD TRAIL...
