JD 3038e Loader won't hold curl
   / JD 3038e Loader won't hold curl #11
Its probably the loader control valve. If you pop the QCs for the curl circuit off the valve does it still happen?
   / JD 3038e Loader won't hold curl #12
Pistons might need to be repacked or replaced, have you done any unusually rigorous work with it lately?
It wasn't the cylinders, I had them rebuilt but they said they didn't see any obvious problems. I put them back on and there isn't much difference. It'm thinking it must be in the loader control valve. Does it have any kind of adjustments?
It doesn't have QC but I could unscrew, but wouldn't the hydraulic oil just drain from the cylinders?
   / JD 3038e Loader won't hold curl #15
Yes it would. With quick connects, it would tell you if the problem were in the cylinder or in the valve.
   / JD 3038e Loader won't hold curl #16
Yeah 2. But youve already determined that it isnt the cyls - so no point. If its not drippin on the floor somewhere it is the curl spool in the valve. It will have to be disassembled to fix. JD ought to have a clue about the valve they use / whether fix is feasible.
larry
OK. Thanks for the responses. Now I have a better idea of what to do next.
2025 MMS MS36C (A53317)
2025 MMS MS36C...
Swict 72" Bucket (A57149)
Swict 72" Bucket...
Spinning Target (A57149)
Spinning Target...
8' Avalanche Snowbox (A55272)
8' Avalanche...
1999 CAT 350E2 Haul Truck (A55272)
1999 CAT 350E2...
1996 Isuzu NPR Box Truck, VIN # 4KLB4B1R8TJ000333 (A57453)
1996 Isuzu NPR Box...
