JD 3038E Homemade Cab II
   / JD 3038E Homemade Cab II #21
Ahhhh going back to work. I ran out of time off also and had to return to work on Monday. Oh well the bills haven't started paying themselves yet.
   / JD 3038E Homemade Cab II #22
Nice work can't wait to see finished product
Sent from my iPad using TractorByNet
   / JD 3038E Homemade Cab II #23
Great work!!! Wishing I had seen this thread before starting mine. I'll have to start a thread and show what I've done.
I had to order some 5/8 OD DOM tube for the door hinges. Ebay had some 12" pieces cheaper than a trip to Denver to buy a full stick. I would never have used 12' of it either. So while I am waiting on the pipe to deliver, I built the door frames. I used 3/4" 16GA tubing. Attached are the pictures of the doors frames in process.
Stryder, i look forward to seeing what you have built. Please share it may help me out. I am designing mine as I go.
Work on the cab has been slow. Finally spent the weekend getting the doors hung. Learned a lesson as I went, the door hinge pins have to be in line or you can't remove the doors. I was lucky and only had to move the bottom hing to back side of the slanting upright. Because I had already built all 4 hinges the same, I had to extend the bottom one 2.25". Now I have to work on building the latch.
Door open
Door closed
Image showing the door closed from front
   / JD 3038E Homemade Cab II #27
I didn't really take many pics as I went but here's the front and back. Still need to build the doors but my broken hub set me back.
   / JD 3038E Homemade Cab II #28
Here are some pics
Looks like a good start. I like the curved top. I picked up some LED lights similar to yours at tractor supply this weekend. They were on the clearance rack for $20. I used 3/4" 16Ga tubing for my door frames. Tried to keep them light weight so they can be removed easily when it's warm outside.
   / JD 3038E Homemade Cab II #30
Great idea on the door frames I'll definitely look into that as well.
2018 Kubota SVL95-2s (A50120)
2018 Kubota...
CONTACT INFO (A53084)
Kent KHB3G Q.A Hydraulic Breaker (A50121)
Kent KHB3G Q.A...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A51573)
IMPORTANT PLEASE...
2010 Chevrolet Impala Sedan (A51694)
2010 Chevrolet...
New Holland Boomer 55 Tractor (A52384)
New Holland Boomer...
