JD 3038E Homemade Cab II
   / JD 3038E Homemade Cab II #21
Ahhhh going back to work. I ran out of time off also and had to return to work on Monday. Oh well the bills haven't started paying themselves yet.
   / JD 3038E Homemade Cab II #22
Nice work can't wait to see finished product
Sent from my iPad using TractorByNet
   / JD 3038E Homemade Cab II #23
Great work!!! Wishing I had seen this thread before starting mine. I'll have to start a thread and show what I've done.
I had to order some 5/8 OD DOM tube for the door hinges. Ebay had some 12" pieces cheaper than a trip to Denver to buy a full stick. I would never have used 12' of it either. So while I am waiting on the pipe to deliver, I built the door frames. I used 3/4" 16GA tubing. Attached are the pictures of the doors frames in process.
Stryder, i look forward to seeing what you have built. Please share it may help me out. I am designing mine as I go.
Work on the cab has been slow. Finally spent the weekend getting the doors hung. Learned a lesson as I went, the door hinge pins have to be in line or you can't remove the doors. I was lucky and only had to move the bottom hing to back side of the slanting upright. Because I had already built all 4 hinges the same, I had to extend the bottom one 2.25". Now I have to work on building the latch.
Door open
Door closed
Image showing the door closed from front
   / JD 3038E Homemade Cab II #27
I didn't really take many pics as I went but here's the front and back. Still need to build the doors but my broken hub set me back.
   / JD 3038E Homemade Cab II #28
Here are some pics
Looks like a good start. I like the curved top. I picked up some LED lights similar to yours at tractor supply this weekend. They were on the clearance rack for $20. I used 3/4" 16Ga tubing for my door frames. Tried to keep them light weight so they can be removed easily when it's warm outside.
   / JD 3038E Homemade Cab II #30
Great idea on the door frames I'll definitely look into that as well.
(8) 2 PLUG VALVES (A52472)
(8) 2 PLUG VALVES...
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A51694)
2022 Forest River...
2014 DITCH WITCH RT45 RIDE ON TRENCHER (A51246)
2014 DITCH WITCH...
2015 Peterbilt 337 Tilt Body w/ Dovetail (A52384)
2015 Peterbilt 337...
2016 Hino 195h Truck, VIN # JHHSPM2H9GK001609 (A51572)
2016 Hino 195h...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
