JD 3032e is here!
/ JD 3032e is here! #1
wnymudd
Western New York State
2009 John Deere 3032e HST, 1953 Ford Jubilee, 1963 Fordson Super Major, John Deere 40, Huskee Lawn Tractor
JD 3032e is here! Took delivery yesterday. Here are a couple pics. Used it yesterday to pull hay wagon. I really like it so far. The kids were just as excited as I was! My little guy had a JD40 before I got mine given to him by his great-grandfather.
/ JD 3032e is here!
/ JD 3032e is here! #3
Nice looking tractor. I've never seen a 305 loader. What are the specs on it?
/ JD 3032e is here! #6
That is always a good day. Where did you buy it-Z&M ? Where in WNY are you? I am in Boston. Have fun(I mean work hard) with it.
/ JD 3032e is here!
Yes I bought it at Z&M. Though I'm not sure I got the best deal I could have, they are the closest to me. It is alot of tractor for the money. I am in Cassadaga. Got to play, I mean work it most of the day. I absolutely love the quick pin on bucket and pallet forks! I can't believe I have gone this long without forks! I must have changed them 6 times today just for fun. Ran the 5' brush hog and rototiller with no problem at all. So far only thing I would change are the sway bars. I wish they were the quick pin type like on the bobcat and kioti and kubotas. They require a wrench to tighten. Anyone have an Idea where I can score some of those?
/ JD 3032e is here! #8
The JD 3x20 series has the quick pin sway stabilizers. Do not know if they can be adapted to the 3032e or not. You can find them on jdparts.com
/ JD 3032e is here!
Ok Cocre thanks I will look them up.
/ JD 3032e is here! #10
First post here so I'm a newbie. Why do the rear rims look bigger on this tractor rather then todays 3032e I saw at the dealer?
/ JD 3032e is here! #11
I would figure the one at you saw at the dealership was equipped with R4 tires. The R1 tires, (that's what the tractor above is equipped with), are a different size from the available R4's, so thus a different rim size is required.
/ JD 3032e is here! #12
Where does this tractor "fit" into the JD line. I see it has the same power as a 3520. What is different?
D.
/ JD 3032e is here! #13
D.
It's like the "value" or "economy" line...less creature comforts. The loader is non-removable and the joystick is up on the mast. There are no split brakes.
/ JD 3032e is here! #14
Are these tractors for women or do you think they will hold up for men with big ideas. I like the money end of this tractor but I just wonder since their not proven.
/ JD 3032e is here! #15
Who knows for sure...THIS guy isn't scared though.
/ JD 3032e is here! #16
No he is not scared. I am looking at this tractor pretty hard... That said, the link you gave did say he has a popping noise in the differential now.
/ JD 3032e is here! #17
I think the 3000 E series tractors will hold up just as good as any other JD. Yeah there the economy tractors, but a lot of what makes them that is the fact that they don't have all the fancy features and trim of the 3x20 series. It's basically like a 3005 w/ a hydro transmission and a non-removable loader. If I was looking, I would be hard pressed not to buy one.
/ JD 3032e is here! #18
I'm looking hard at this same tractor with FEL. I have everything else I need for now. The one hold-back is that JD does not yet offer it with a back-hoe option. I could probably get one from woods etc, but hopefully Deere will offer one in the future.
If you don't mind my asking, what did that set-up cost you? I have been getting quotes in the 15K range with FEL. I live near Houston, TX.
/ JD 3032e is here! #19
I am owner of pictured 30302e w/ large stump. I have the tractor back & was only at dealer for 5 days. Problem was the Diff-Lock adjustment was not correct & was set that way from factory. All is well now & problem is fully documented with Deere & my dealer & I also have printted copies myself for any future problems related to this so I am covered. I think anyone actually wanting to work one of these won't be dissapointed, the loader hydro's are very responsive. Inb short a very powerfull & nimble tractor. MIne is used around heavily tree'ed 5.8acre piece & HST is really fast for the obsticul course & real fast loader work. Make sure you get your tires filled. I have not babied this 3032E at all & worked it hard, not abuse, just hard since day 1 & will continue too.
Joe
/ JD 3032e is here! #20
Nice tractor. Was wondering about the pallet forks? I've seen several times I could have used a set. Are they just for the E-series or do they fit other tractors as well? Don't suppose the dealer threw it in with the deal?
2006 MACK CHN613 (INOPERABLE) (A67714)
2006 MACK CHN613...
CAT 320 Excavator Compactor Wheel (A68134)
CAT 320 Excavator...
2026 SG45 Hydraulic Stump Grinder Skid Steer Attachment (A66734)
2026 SG45...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
PORTA POTTY (A68842)
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
