JD 3025E rockshaft problem
/ JD 3025E rockshaft problem #1
KRH
E\'ville, NY
JD 5225 MFWD w Power Reverser; 2010 JD 110 tlb; 2007 JD 4520
Just bought a used 2017 JD 3025E with a front end loader. Before I made the purchase I noted that the 3 point hitch arms went up and down. I asked the dealer if there were any problems with the machine and he replied in the negative. Now that I have the machine and home and going over it more closely, I have discovered that the 3 point hitch arms are either completely up or completely down. They will not stay up at any point in between. If you pull the lever to raise the arms, the arms will rise to very top and the bypass value will engage. So I pull the lever back enough so the bypass will stop.
So my first job was to make sure that the there was nothing hanging up on the outside that would prevent their proper operation. I lubricated both the shaft for the lever(#19 on diagram) which raises/lowers the 3 point hitch arms and the shaft for the position feed back arm(#27 on diagram). Both the lever and position feed back arms/shafts are working as they should, at least, on the outside. However the 3 point hitch arms still will not stay in any position other than completely down or up. So something not working on the inside. I assume the shafts are not engaging with the HYDR./PILOT Control Valve(#25) inside. Or the shaft for the position feed back arm is bad/broken???
Thoughts? Thanks in advance for your time and wisdom!!!
/ JD 3025E rockshaft problem #2
Sounds like you are on the right track.. do you have the operators manual? Anything about a draft setting? (don't think you have that, so just a guess).
Time for a discussion with the salesman at the dealer, or the service dept. at the dealer. Salesmen may say anything, and not have a clue.
Going to get an operator's manual. Checked it out on line and the only adjustment that can be made is the rate of drop. I have sent the salesman a message as well.
Thanks for your input.
2008 International 4300 Altec AT40C 34ft. Bucket Truck (A64194)
2008 International...
2025 Auger Bit Skid Steer Attachment (A64553)
2025 Auger Bit...
8ft Fork Extensions (A64553)
8ft Fork...
2003 Jeep Liberty 4x4 SUV (A64557)
2003 Jeep Liberty...
2025 Auger Drill Bit Skid Steer Attachment (A64553)
2025 Auger Drill...
2016 Jeep Patriot Sport SUV. (A64557)
2016 Jeep Patriot...
