Jd 300b hydraulic questions
   / Jd 300b hydraulic questions #1
65sixbanger
Bryan,tx
Jd 300b
Howdy,
I have a jd 300b loader that has had slow loader movements since I've owned it. I have changed filters, stroke control valve, and adjusted stand by pressure to 2300. The book says the boom up cycle time should be about 4 seconds, mine is around 7-8 seconds. Transmission pump pressure stays above 40-50 psi when using loader mid throttle so I don't think this is a charge circuit problem. I know the steering column can cause a lot of hyd problems, but I capped the line off that goes to Column with no difference. I have shimmed the pressure control valve up to 1750 and same thing. I only have about 15gpm at only 1000 psi and it's very chattery. I'm about to pull the front pump, I just wanted some reassurance or other thoughts maybe.
Thanks,
Lance
   / Jd 300b hydraulic questions #2
Does your tractor have a 3 pt? If so with 3 pt raised,engine running look in hyd filler hole for spraying oil. Where are you attaching gauge to only get 1000 psi?
It has 3 pt, but I have resealed the spools and set the valves, I doesn't appear to be leaking. I t-eed into the main pressure line that leaves the pump and goes to accumulator. It will only put out 1000 psi at 15 gpm instead of 1750 at 19-20 gpm. has no problem sitting at stand-by pressure, it just doesn't have the flow
   / Jd 300b hydraulic questions #4
It's possible there are are some faulty inlet/outlet valves in main hyd pump. Have you ever checked trans pump flow? It should be around 5 GPM.
UNUSED WOLVERINE 66" BOLT ON PALLET FORKS (A51248)
UNUSED WOLVERINE...
2020 Terex RL4 Towable Light Tower (A51691)
2020 Terex RL4...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
UNUSED CFG INDUSTRIAL MH12RX EXCAVATOR (A51247)
UNUSED CFG...
City of Pinellas Park (16920) VIN: 1GNLCDECXGR265858, Title Brand: Police Year: 2016 Make: Chevro... (A51694)
City of Pinellas...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
