JD 2950 MFWD Drive Shaft
   / JD 2950 MFWD Drive Shaft #1
bigblock76
Little Britain, Ontario
John Deere 2120, John Deere 3140, John Deere 2950, John Deere 7700 Combine, John Deere STX38
Still going over this tractor... the drive shaft appears to have a lot of wobble from the output of the the transmission. The wobble is on the driveshaft yoke to the spline of the output shaft. The U Joint seems to be okay.
What is most likely the wear item? The yoke spline or the output shaft? Is the output shaft a big to do to replace if needed?
   / JD 2950 MFWD Drive Shaft #2
Usually the cast iron yoke will wear faster than the shaft. Even if shaft is worn, it is not a huge job to replace. The bottom cover needs to be removed, then the seal housing from around the shaft comes off. Then the shaft will pull out while you support the clutch. The clutch can be then lowered to rebuild the mfwd clutch if you like.
Is it worth trying to find a good used yoke from a scrap yard or is aftermarket the best way?
   / JD 2950 MFWD Drive Shaft #4
The yoke is available new from deere. part number AL37071. It is alittle pricey at around $162 USDollars, but It may be difficult to find a used one in better shape than what you have. Aftermarket is alternative if you don't mind doing the research to find one to match.
2008 Chevrolet Express Passenger Van (A51692)
2008 Chevrolet...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
Year: 2014 Make: Ford Model: F-450 Vehicle Type: Pickup Truck Mileage: 193,532 Plate: Body Type: 2 (A51692)
Year: 2014 Make...
1996 Allegheny 35FT 25 Ton Flatbed Equipment Trailer (A51692)
1996 Allegheny...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A51692)
2015 Freightliner...
2011 Ford F-350 Enclosed Service Truck (A51692)
2011 Ford F-350...
