JD 2950 Battery Drain
/ JD 2950 Battery Drain #1
tvanstee
Saskatoon, SK
John Deere 2950, 1979 Satoh Buck
Hi,
I have a 1984 JD 2950 cab tractor that has been giving me some issues when trying to start. If I try and start the tractor sometimes when I turn the key I will get no response other than a single click, but if I use the old screwdriver method it starts just fine. If the ignition does decide to work a lot of times I will have very low power to the starter and will have to boost the tractor. I have put new batteries on and it made a difference for a couple weeks but lately I am back to the same old problem. I am no expert at mechanical work, but I am guessing maybe alternator issues. Any advice would be greatly appreciated.
Cheers
/ JD 2950 Battery Drain #2
Since it starts fine with a screw driver, I think the alternator is fine.
I think your problem lies in the start circuit. You need to determine what is in this circuit and then check components. I am guessing if there is a relay it could have worn contacts, same for ignition switch. Also check connectors.
Sorry, the screwdriver trick gives me the same runaround most times, I usually have to boost it.
/ JD 2950 Battery Drain #4
Cab or open station? If open station relocate battery ground cable from battery box to starter mounting bolt. Check ALL battery cable connections to be sure they're clean & tight. Disconnect ground cable and insert a test light in it's place,if light burns start disconnecting electric components until light goes out
I think I got it figured out, what I did was replace the grounding cables and grounded them direct onto the starting mounting bolt, after that she fired up just fine. Thanks for the help guys.
/ JD 2950 Battery Drain #6
Except for costing less to build I never understood why JD engineers used the battery box for a battery ground cable attaching point for many,many years. After a few years the battery box floor gets rusty and loses some electrical continuity where box contacts clutch housing.
/ JD 2950 Battery Drain #7
Accountants over ruled the engineers
