JD 290 planter?
/ JD 290 planter? #1
monkeydo
Ford 800
I believe I have a JD 290 tractor drawn 2 row corn planter. It has two 15" rubber tires that need to be replaced. How do I go about getting the wheels off (out of) the planter? Thanks!
/ JD 290 planter?
How do I get the wheels/tires off my JD 290 planter?
/ JD 290 planter? #3
please post picture
/ JD 290 planter? #5
There were two types of wheels that used rubber tires on the 290 planter. The earlier rubber tired units had spoke wheels and required that you remove two cap screws at the ends of the axle then lift the planter until the axle and wheel drop down. Be sure to remove the drive chain! The later units used a four bolt press steel wheel but removal of the axle and hub was the same then the four lug bolts are removed to separate the wheel from the hub.
2016 Chevrolet Caprice Sedan (A61569)
2016 Chevrolet...
72'' Fork Extension (A61567)
72'' Fork...
New/Unused 11ft x 19ft Metal Garage Shed (A61166)
New/Unused 11ft x...
New/Unused Landhonor Electric Hoist (A61166)
New/Unused...
2025 Poly Fuel Tank with Electric Pump (A61568)
2025 Poly Fuel...
2013 Ford F-250 Pickup Truck (A55973)
2013 Ford F-250...
