JD 2720 - Bush Hog Advice
   / JD 2720 - Bush Hog Advice #1
Fanatical1
Hocking Hills, Ohio
John Deere 2720
I recently purchased a slightly used JD 2720 and need to buy a Bush Hog.
I will be using for mainly keeping the woods controlled along the paths and driveway, versus using it
for tall grass or weeds. Mostly very small saplings and vines, brush etc....
I'm thinking a 5 foot Frontier might good, but wanted advice on width and brand?
   / JD 2720 - Bush Hog Advice #2
My neighbor uses a 4' Frontier with his 2520. But, he has tackled some larger brush with it, too! So, if you're not gonna take on 3" trees the 5' might be just fine. Heavier, larger shrubs, trees, etc. might be too much with a 5' cut.
AKfish
   / JD 2720 - Bush Hog Advice #3
- Spindifferent
Good information. Maybe the 5' versus the 4' would be a good choice for reaching into the sides of the trails.
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2008 CATERPILLAR 226B2 SKID STEER (A51246)
2008 CATERPILLAR...
John Deere 6430 Side Arm Tractor (A51573)
John Deere 6430...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A52748)
Kubota BX2680...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
