Flail Mower JD 25A Flail Question
/ JD 25A Flail Question #1
picklerick
Pepperell,MA
None
I have an old JD25A flail that I picked up second hand. It came with no manual but I was able to look it up online to get the oil and grease specs. However, unlike the recent models, the gearbox only has one fill plug instead of one for adding and another for checking if it’s full. How do I make sure I’m filling it but not overfilling it? Any advice?
Thanks!
/ JD 25A Flail Question #2
Same way you fill/check a rear end housing on your truck. Remove plug. Add fluid until it runs out. Replace plug.
/ JD 25A Flail Question #3
I'd say given the position of the plug....fill to the lip of the plug.
/ JD 25A Flail Question #5
Sometimes gearboxes will have a vent plug in the top of the case. That can be removed and used to pour in fluid if that's easier. Either way, use the side plug to check full level.
/ JD 25A Flail Question #6
Yep, as others mentioned.
I just checked gearbox oil in my 25A yesterday and took it out for a few laps around my field. (Was checking if I have the governor on my tractor adjusted properly- it's pretty close!)
Mine's old, beat, twisted, and if ya lift it while it's spinning or back up one or two of the blades will contact the hood and make a terrible racket!
I am, however, always impressed with the finish it leaves behind, despite having VERY old knives and being beat to snot.
UNUSED WOLVERINE HYD MINI 4IN1 BUCKET (A64281)
UNUSED WOLVERINE...
2022 CATERPILLAR 299D3 XE SKID STEER (A64279)
2022 CATERPILLAR...
2020 ISUZU NRR 4X2 S/A 22FT BOX TRUCK (A59912)
2020 ISUZU NRR 4X2...
Case 1020 25ft Draper Head (A63118)
Case 1020 25ft...
3pt 6' Rotary Mower (A64119)
3pt 6' Rotary...
UNUSED WOLVERINE QC5-26-20G QUICK COUPLER 5 (A64281)
UNUSED WOLVERINE...
