JD 2520 with independent (joy stick controlled) MMM lift kit problems
   / JD 2520 with independent (joy stick controlled) MMM lift kit problems #1
sandalwood
New Brunswick, Canada
L5460 Kubota
My neighbor has a JD 2520 which has a dealer installed independent (loader joystick controlled) mid-mount mower lift kit. It has worked well for 3+ years but now usual joystick movement to raise and lower the mower (similar to raise or lower loader arms) no longer works.
If he connects the hydraulic hoses to the other 2 joystick couplers (curl/dump movements for loader) the mower will raise and lower.
His hydraulic fluid level is correct and there is no sign of a leak.
Has anyone else had this problem?
Does sound like a coupler or valve problem?
   / JD 2520 with independent (joy stick controlled) MMM lift kit problems #2
does the loader work up ,down, dump, curl?
   / JD 2520 with independent (joy stick controlled) MMM lift kit problems #3
being since the deck cylinder works fine when you switch connects, sounds like you have a valve problem.
I thought this also. He tells me it is intermittent. If it stops working, switching to the other 2 couplers and then back to the original ones may allow it to work again for a while. Intermittent obstruction somewhere?
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52141)
2018 FREIGHTLINER...
2017 CATERPILLAR 259D SKID STEER (A51242)
2017 CATERPILLAR...
2000 INTERNATIONAL 4700 (A52472)
2000 INTERNATIONAL...
DHE 38-7 7 SHANK ALL PURPOSE PLOW (A51243)
DHE 38-7 7 SHANK...
2019 FORD F550 XL SERVICE TRUCK (A51243)
2019 FORD F550 XL...
2014 CATERPILLAR 740B OFFROAD DUMP TRUCK (A51242)
2014 CATERPILLAR...
