JD 2520 with independent (joy stick controlled) MMM lift kit problems
   / JD 2520 with independent (joy stick controlled) MMM lift kit problems #1
sandalwood
New Brunswick, Canada
L5460 Kubota
My neighbor has a JD 2520 which has a dealer installed independent (loader joystick controlled) mid-mount mower lift kit. It has worked well for 3+ years but now usual joystick movement to raise and lower the mower (similar to raise or lower loader arms) no longer works.
If he connects the hydraulic hoses to the other 2 joystick couplers (curl/dump movements for loader) the mower will raise and lower.
His hydraulic fluid level is correct and there is no sign of a leak.
Has anyone else had this problem?
Does sound like a coupler or valve problem?
   / JD 2520 with independent (joy stick controlled) MMM lift kit problems #2
does the loader work up ,down, dump, curl?
   / JD 2520 with independent (joy stick controlled) MMM lift kit problems #3
being since the deck cylinder works fine when you switch connects, sounds like you have a valve problem.
I thought this also. He tells me it is intermittent. If it stops working, switching to the other 2 couplers and then back to the original ones may allow it to work again for a while. Intermittent obstruction somewhere?
2017 terex warrior 1800 screener (A50322)
2017 terex warrior...
Bush Hog 2615 Batwing Mower (A50514)
Bush Hog 2615...
Land Honor Quick Attach Power Rake (A50514)
Land Honor Quick...
2008 Ford F-250 Knapheide Service Truck (A50323)
2008 Ford F-250...
SET OF HOMEMADE FORKS (A51243)
SET OF HOMEMADE...
12' UTILITY SERVICE TRUCK BODY (A51244)
12' UTILITY...
