JD 2520 pressureless return?
/ JD 2520 pressureless return? #1
gertjand
Netherlands
JD 2520
Hi all,
Got a question. I have a John Deere 2520 with 4 hydraulic couplers for the FEL. Now I want to use a trailer with lifting cilinder. That one has only one hose and it drops by gravity. Are the Fell couples able to handle the retour? The Fell couplers are grouped in 2 x 2 for up and down and for loader up and down. If I connect one hose to FEL up. And I push FEL down does the fell up becomes pressureless so it drops by gravity?
/ JD 2520 pressureless return? #2
You could place boom control lever in float position to accomplish what you desire or stop engine from operating while lowering trailer bed
/ JD 2520 pressureless return? #3
I think float position would quickly drop the box. Perhaps in some cases, too quickly.
FEL hyd connector(s) will handle a dump trailer. Use FEL joystick to control rate of rise and fall of dump box just like you do the loader.
Yes, the box will lower by the force of gravity when the hyd oil in the one “push up” hose to the cylinder isn’t blocked from returning to the tractor. It’s this blockage that keeps the dump box in the elevated position. The oil is trapped as has no where to go, cylinder can’t move. Moving the FEL joystick in the “opposite of lift” direction opens a path in the FEL hyd valve for the oil to flow back through the valve as the hydraulic cylinder retracts due to gravity.
/ JD 2520 pressureless return? #4
Hi all,
Yes.
Many thanks, will give it a try tomorrow and keep you posted. First get a matching coupler.
/ JD 2520 pressureless return? #6
My first thought on lowering the trailer with a single acting cylinder connected to one of the two ports normally associated with a double acting cylinder is that the hydraulic system will have to go into "relief mode" since it is trying to force fluid out of the unused port. I don't think that would be a concern other than the temporary squeal of the fluid going over the relief valve.
I don't know if the Deere 2520 is an open center or closed center hydraulic system. I'm thinking that, on a closed center load sensing system, the relief valve wouldn't have to open as the system wouldn't see a demand for pressure. Is that correct?
/ JD 2520 pressureless return? #7
The 2520 CUT has an open center system. Yes, it will be in relief while the trailer is lowering, but that won't hurt anything.
/ JD 2520 pressureless return? #8
Depending on the geometry of the dump trailer.....and cylinder.....gravity down can be slow. I personally wouldnt want to wait that long for it to lower while forcing oil over relief. Because as others said....it will go into relief due to the unused port.
Simply use either lift or lower to raise the trailer (which one really dont matter). Then just use float to lower it. Using loader float to lower it wont let the trailer lower any faster than forcing the unused port to open the pressure relief. Because in BOTH cases....the oil coming back from the trailer has a clear path back to tank. But using float mode also gives the pump flow a clear path back to tank as well instead of no where to go and forcing the relief open.
/ JD 2520 pressureless return? #9
In general these comments are correct, but don't worry about "float". When a single acting cylinder is attached to one port, you get backflow from gravity when you go into the opposite position. Float allows backflow through both ports, which you don't need.
I know this because the mower independent lift system on a John Deere is a single acting cylinder. No need to go into float to lower the deck.
/ JD 2520 pressureless return? #10
Its not about allowing backflow through both ports. Its about not blocking the pump flow causing it do deadhead and go over the relief.
A few seconds of relief here and there isnt an issue. But gravity down trailers can take 30 seconds or more at a time to lower. And thats a long time to be deadheading your hydraulics at max pressure and putting it over the relief.
And seriously.....if you have loader raise for your dump trailer raise....and loader lower for dump trailer lower....rather than sit there and hold the lever how hard is it to simply click it into the float detent?
/ JD 2520 pressureless return? #11
If worried about dead heading, err.. having oil pass through relief valve, turn the engine off when lowering.
/ JD 2520 pressureless return? #12
Guess I aint too worried about it. Not my tractor and pump that is taking the abuse.
Not sure why everyone is getting so defensive and coming up with a bunch of other alternatives rather than simply hit float to lower? No deadheading, no shutting the tractor off only to restart it 30 seconds later, etc.
I hope the OP understands all of this and makes the correct decision
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A63276)
2018 FREIGHTLINER...
2015 Hyundai Genesis 3.8 Coupe (A61574)
2015 Hyundai...
EZ Go TXT Golf Cart (A61166)
EZ Go TXT Golf...
Fimco 45 Gal Sprayer (A64119)
Fimco 45 Gal...
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
2014 Chevrolet Sonic Sedan (A61574)
2014 Chevrolet...
