JD 2520 POWER BEYOND
/ JD 2520 POWER BEYOND #1
YASH2520
JOHN DEERE 2520
I have just installed a power beyond kit on a JD 2520 compact tractor. I just want to verify which port would be the pressure port and which would be the tank port??
Based on the sticker, it looks like the top (female coupler) would be the pressure port.
Any insite would be greatly appretiated,
/ JD 2520 POWER BEYOND #2
If this is for a two way cylinder setup then both ports are pressure. They just swap from pressure to dump as you change directions on the flow.
/ JD 2520 POWER BEYOND #3
On my 4110 the top (female) connector is the out or pressure side. You probably know you must always keep the loop completed. If you aren't using a backhoe or other attachment, the connector hose must be used! Jason
Welcome to TBN! You will find a lot of helpful advice here!
Thanks for the replies.
I know that if using a two way cylinder it does not really matter, but being in industrial maintenance I have learned from experience that it is better to have all the fitting connected as intended, less errors latter.
/ JD 2520 POWER BEYOND #6
rockyridgefarm said:
the female is the pressure port.
you can say that again!
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A63569)
2015 VANTAGE...
Ammann AV33E Roller (A65579)
Ammann AV33E...
2012 Ford F-350 4x4 Ext. Cab Pickup Truck (A61568)
2012 Ford F-350...
3 Point Trailer Mover (A65640)
3 Point Trailer...
Massey Ferguson 10 Square Baler (A65640)
Massey Ferguson 10...
Anco 3Pt Ditcher (A66408)
Anco 3Pt Ditcher...
