JD 24T Versus NH 268 baler
   / JD 24T Versus NH 268 baler #1
idaho52
Meridian, ID
Kiota CK 25
Can anyone tell me which one might be better to use with a Kiota CK25 will be baling maybe 20-30 acres 4x a year. Thanks
   / JD 24T Versus NH 268 baler #2
The one with the closest parts dealer. Also with a TSC nearby for consumable parts: pickup teeth, twine, grease, shear pins, and maybe a tire or two.
Have dealers for both close.....which most likely be more reliable? Understanding age/condition...
   / JD 24T Versus NH 268 baler #4
asking which is more reliable for a 40 year old machine with loads of moving parts? If your asking the question at all, I'm already worried. Make sure you have exceptional local support. Your going to need help.
   / JD 24T Versus NH 268 baler #5
I don't think the Kioti CK 25 is enough tractor for either baler. Ken Sweet
Thank you Ken. Your response is helpful. Do you have any idea what the HP requirements are? I've checked online and haven't been able to come up with much....Thanks
Nothing personal, Messick, but your response was typical of a dealer and frankly somewhat insulting...... I don't have 1000's to spend on a machine either to buy or fix.....and I've probably been turning wrenches longer than you where even a gleam in your daddy's eye. That being said, do you actually have any input as to which machine is more reliable? Thanks
   / JD 24T Versus NH 268 baler #8
I think you could squeeze by on hp. it is the physical size and weight on the CK25 that worries me. Either baler would probably outweigh the tractor. Ken Sweet
Thanks Ken, upside here is most ground fairly flat.......have a small hill in back, maybe 300' up or down, but it would be straight up/down, no side traveling....
   / JD 24T Versus NH 268 baler #10
I too agree the tractor is too small physically for a baler. Balers put out quite a bit of force for and aft and you need some weight on the tractor to keep it from pushing it around.
Remember when those balers were made, compact tractors weren't even around. Those balers were pulled by much heavier utility tractors or row crop tractors, i.e. 3010, 2020U, etc..
A lot heavier than today's compact tractors.
2016 TRAILSTAR 40FT DUMP TRAILER (A56129)
2016 TRAILSTAR...
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
2020 Ford F-250 4x4 Crew Cab Pickup Truck (A55973)
2020 Ford F-250...
2014 INTERNATIONAL PROSTAR+ (A58214)
2014 INTERNATIONAL...
2016 John Deere 5055E 4WD 59HP Utility Tractor (A55973)
2016 John Deere...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
