jd 245 hot starting probs
   / jd 245 hot starting probs #1
jimbo64
my gt245-starts fine when cold, when i run it for awhile and then shut it down, it will not restart-let it sit about 15 min and then it will start but not easily, get a puff of blue smoke and, runs rough for a couple minutes and then levels out-------kawasaki 20 hp-any ideas on where to start looking--------thanks-jimbo------changed plugs, no help-was serviced in march and i replaced all filters-am running synthetic oil in crankcase and 93 octane fuel with stabilizer in it. Tractor Just started doing this.:mad:
   / jd 245 hot starting probs #2
Do you have spark at the plugs when "no start hot" problem occurs?
If no, then look at the spark side of the equation.
If yes, then look at the compression side...rings/valves
have spark,was thinking perhaps it's vapor locking, would this not be symptoms of a vapor lock- will check this out next time out to barn.
come on experts-know that youre out there-some one else must have had and solved this problem
(APPROX 21) UNUSED LANDHONOR PINS (A54757)
(APPROX 21) UNUSED...
30050 (A53424)
30050 (A53424)
Powder River Squeeze Chute (A55218)
Powder River...
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
2005 Ford F-750 Truck (A53422)
2005 Ford F-750...
1472 (A51247)
1472 (A51247)
