jd 2350 temp gauge
   / jd 2350 temp gauge #1
tmacod1
jd 2350
I have jd 2350. The temp gauge is acting up. I have replaced the thermostat, sending unit, checked wiring. It will still measure hot with minutes of starting the tractor under no load. You can tap gauge cluster and the needle will jump to normal and then back to hot in a few minutes. Even when hot you can touch the coolant hoses with bare hands. Any suggestions? I was wanting to put a new gauge but it is part of the entire console. Can i just use an aftermarket gauge and the current sending unit?
   / jd 2350 temp gauge #2
If you use an aftermarket gauge you will need to use a sender to mach. The resistance will most likely be differant
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A55301)
2016 KBH...
2025 GIYI VR66 66in Vibratory Roller Skid Steer Attachment (A53421)
2025 GIYI VR66...
Utility Trailer (A52377)
Utility Trailer...
2014 Ford F-350 4x4 Cab and Chassis Truck (A53422)
2014 Ford F-350...
