JD 23053 point hitch & Mower deck
   / JD 23053 point hitch & Mower deck #1
butchy
JD2305
I never use my 3 point hitch on my 2007 2305. I removed the 3 point hitch and afterwards I could not raise my mower deck. I noticed there is a steel piece that gets lifted by the left lift arm of the 3 point hitch.....that in turn pushed some rod forward that somehow lifts the 54" mower deck. Sorry for my pathetic description but I know you guys really know this stuff.
I had to reattach the left 3 point hitch arm so that once again it would lift my mower deck. Now I have a tractor that has one arm sticking out the back and looks stupid. Either I will fully reattach the 3 point hitch so it looks somewhat normal, or someone is going to tell me something I can do so that i can operate my mid mount mower deck with the 3 point hitch removed.
I noticed there is a lever to the left of my seat...a 3 position PTO selector lever...........does that have anything to do with this? I also read that there are mechanical lift mechanism to operate mower deck and a hydraulic lift mower deck operator. I assume I have the mechanical lift version.
Thanks guys, hoping for soemone out there to educate me.
   / JD 23053 point hitch & Mower deck #2
The left 3-pt hitch arm uses a tab and rod to raise and lower the mower deck. That is why it's call a mechanical lift. JD sells an independent lift kit which replaces the mechanical rod with a hydraulic cylinder. It is actuated by the SCV control and you use one of the 4 hydraulic connections (I used the green one) on the right side floor board. My kit cost $150 in 2006. It was an easy install.
Thank you all very much, I am ordering it Monday !!!!!!!!!!
   / JD 23053 point hitch & Mower deck #4
As noted you have the mechanical lift that uses the 3 point to lift the mower deck. Is there any reason you don't want the 3 point hitch on the machine? Technically it would be possible to fabricate a lift arm connector to replace the 3 point arm, but I would just leave the 3 point system intact.
The PTO selector just engages front, rear or both PTOs. Nothing to do with the lift. The independent lift system has a new hydraulic cylinder which is operated by the loader control. With this system you can independently control the 3 point height but you lose the loader curl function while using the mower lift.
   / JD 23053 point hitch & Mower deck #5
Not to hijack this post, I’ve always considered getting the hydraulic lift for my 2305. Any one know the part# to order ? And does the deck go any higher with it ?
   / JD 23053 point hitch & Mower deck #6
The part number for the LVB25630. The same kit works on the 2305, 2320 & Gen 1 2025R. I do not know if it will raise the deck any higher.
   / JD 23053 point hitch & Mower deck #7
Awesome. Thanks for that.
LOT LOCATIONS (A57880)
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
2020 Ford F-250 (A55973)
2020 Ford F-250...
2009 Dodge Ram 3500 Flatbed Truck (A55973)
2009 Dodge Ram...
2014 Ford Explorer SUV (A56859)
2014 Ford Explorer...
2020 DRAGON ESP...
