In my first encounter, when the engine began to knock I reduced power and stepped on the clutch to unload the engine. And that was when the engine "ran away". I later discovered that the fuel return line connection at the tank filler neck had separated.[/quote}fritza2tt
So If I'm understanding you correctly you reconnected the return line hose at the tank but didn't remove the diesel soaked air cleaner elements and engine immediately ran fine?????????
If your tractor(one out of 1000's of JD utility models built) did as you state I think that would not constitute a "design flaw"[/QUOTE]
Tx Jim, there was no Diesel-soaked air cleaner present. Try to visualise this: you are in the field bush-hogging. The engine is running between 1,500 and 2,000 RPM. Suddenly the fuel return line slips off and fuel ''dribbles' down behind the tank in front of the radiator cooling fan. The fuel is sprayed and sucked in by the fan, mixes with the air and forms a combustible fuel air mixture. This fuel/air mixture is ready to burn if a spark would set it off. But instead some of it is sucked into the air cleaner. (If a spark was generated there, the air cleaner would explode.) From the air cleaner the ready to burn fuel/air mixture continues into the engine where the heat of compression becomes the trigger it and makes it detonate!. There is no progressive burning here, the entire charge detonates simultaneously at once and you hear it as a ping or knock.
