JD 2210 Rear Axle Seal
   / JD 2210 Rear Axle Seal #1
shs28078
JD 2210
Is there a trick to getting the rear axle off to replace the seal?
There are two bolts that I can't get to without taking the transmission out!
   / JD 2210 Rear Axle Seal #2
:welcome:
Looks like remove the rear housing and then remove the snap ring that holds the axle from sliding out.
Look in jdparts for some of the breakdown. Doesn't look like a trick to do.
Thanks for the quick reply! I thought it would be a snap but the top two bolts on the housing (the two above the 4 bolt on the diagram) are entirely inaccessible.
   / JD 2210 Rear Axle Seal #4
What have you removed so far?
I'm an idiot!
I jacked the tractor up by the transmission, instead of by the frame!
   / JD 2210 Rear Axle Seal #6
If your an idiot your not the only one.
I can remember trying to very hard to get my rear brake drums off my car with the parking brake engaged:eek:.
Actually, that wasn't the problem.
Although I still may be an idiot.
I'm back to thinking I have to completely unbolt the transmission from the frame. Does that sound right?
   / JD 2210 Rear Axle Seal #8
No, it does not "sound" right (but it may "be" right :) ). But then a pic or two of what you are looking at might help. Is the frame in the way of getting at the two bolts on the top?
(for posting pics, just get a digital pic file on your computer where you know its file location, then click on "Go Advanced" button next to the quick reply button to browse and upload your pics to your post)
   / JD 2210 Rear Axle Seal #9
Looking at jdparts some more, I'd recommend you get a tech manual CD for your 2210, being that you are willing to dig into the mechanical end of your tractor. That will tell you what you need to disconnect and remove while going after removing the transaxle. Likely you will need to remove the drive shaft, unbolt from the frame, lift the frame and remove the transaxle before removing the housing around the axle.
I ordered the Tech Manual, but in the meantime, I got it off.
I can't believe it was that difficult. When I get the manual, I can check my work!
Thanks for the responses.
2015 VOLVO TRUCK VN SERIES (A50854)
2015 VOLVO TRUCK...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2004 Big Tex 10PI 18ft T/A Pipe Top Utility Trailer (A49461)
2004 Big Tex 10PI...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A50854)
2013 XLR...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2010 INTERNATIONAL DURASTAR 4300 CARGO TRUCK (A50854)
2010 INTERNATIONAL...
