JD 2210 Advantage Series Compact Utility Tractor
   / JD 2210 Advantage Series Compact Utility Tractor #11
I clicked on the link when it was first posted and it worked fine. I just tried again and the JD site is having problems.
   / JD 2210 Advantage Series Compact Utility Tractor #12
I've navigated the JD site, found the new Advantage Series, but it only includes the 790 & 990 tractors.
Jim
If you go into the build option, the 2210 is still listed there as a choice under the advantage series tractors. It seems that maybe Deere posted the information to their web site a little prematurely. It never seems like the IT department and the rest of the corporation have a good line of communication. The way I see it, the web should be the first media used to generate interest and showcase new equipment and technologies. Just my two cents.
   / JD 2210 Advantage Series Compact Utility Tractor #14
Thanks guys, found it thru the configurator but, dang, no picture...
Jim
   / JD 2210 Advantage Series Compact Utility Tractor #15
i have talked to three different dealers and none of them have ever heard of it. however another one said he was going to a meeting in louisville and would let me know more about it when he got back
   / JD 2210 Advantage Series Compact Utility Tractor #16
Talked with local dealer, he said Deere sent him a notice announcing the JD 2210 tractor but no delivery date. His best estimate for availability is late fall, early spring... Attached is small picture of JD 2210
   / JD 2210 Advantage Series Compact Utility Tractor #17
There is also a 62 inch deck. I have operated the tractor the BX has nothing on this little power house....
edv
   / JD 2210 Advantage Series Compact Utility Tractor #18
is the space when your sitting on it like a 790 or like a 4010?
   / JD 2210 Advantage Series Compact Utility Tractor #19
like the 4000.....
edv
   / JD 2210 Advantage Series Compact Utility Tractor #20
Re: JD 2210 Advantage Series Compact Utility Tract
Does anyone know if this another all-Yanmar model like the 7/990s?
STORAGE FEES (A52141)
2021 Caterpillar 304E2 Mini Excavator (A50322)
2021 Caterpillar...
John Deere 7720 Turbo with Head (A52128)
John Deere 7720...
Quick Attach Pallet Forks (A47384)
Quick Attach...
EZGO GOLF CART (A50323)
EZGO GOLF CART...
2015 Ford Expedition EL XLT SUV (A50324)
2015 Ford...
