JD 2210 Advantage Series Compact Utility Tractor
   / JD 2210 Advantage Series Compact Utility Tractor #21
Re: JD 2210 Advantage Series Compact Utility Tract
You want a picture? OK, I'm attaching one :)
   / JD 2210 Advantage Series Compact Utility Tractor #22
After reviewing the X595 series list price, it seems the 2210's list price is less $$$, and has the same features as the x595, plus a rear PTO, tph and rops. What's up with that. REX
   / JD 2210 Advantage Series Compact Utility Tractor #23
According to the dealer I talked with, it's a all Yanmar tractor. Let's hope Yanmar uses a little more cast iron & steel then in the 4010. The JD 4010 was a disappointment, as I had a hard time finding a place for a magnet to stick..
I've come to expect aluminium allow, plastic an fiber glass on cheap yard/garden tractor but for over $10,000 dollar they can afford a little cast iron & steel.
   / JD 2210 Advantage Series Compact Utility Tractor #24
Another JD 2210 Compact Picture
Here's a picture I scanned from a JD dealer marketing bulletin. Sorry, the quality isn't the greatest.
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2008 Genie S-65 65ft Articulating Boom Lift (A50322)
2008 Genie S-65...
SCAN TO RECEIVE TEXT UPDATES (A51243)
SCAN TO RECEIVE...
2015 Ford E-350 Passenger Bus (A50323)
2015 Ford E-350...
Tallman Water Pump (A50774)
Tallman Water Pump...
