JD 216
/ JD 216 #1
Blaneypark
Charlevoix Mi
JD 790, JD4100,JD318,JD216 Grasshopper 322D,Wright 52 Stander
After sitting my 216 won't even turn over When I turn the key on, I just get a clicking in the selenoid. I can turn the engine over going direct to the starter with jumpers. I'm thinking the selenoid is bad. How does one test it?
/ JD 216 #2
Sounds more like time for a new battery.
/ JD 216
Has a new Battery, Posts are clean, Cleaned the ground wire. Cleaned all positive connections to selenoid and starter.
/ JD 216 #4
Put Jumper Cables from the positive on your battery to the positive on the solenoid to rule out that wiring then touch the positive to the positive on the starter motor. When jump to the positive on the solenoid you will either have to turn the key while touching the posts or you can jump the 12 volts to the switched terminal as well.
/ JD 216
Checked selenoid and it was bad put a new on on and she starts like a 47 Packard Thanks for the help.
429835 (A61166)
429835 (A61166)
2024 BIG TEX 102" X 25' GOOSENECK TRAILER (A65054)
2024 BIG TEX 102"...
CATERPILLAR D9T CRAWLER DOZER (A64279)
CATERPILLAR D9T...
2015 Kubota RTVX1100C (A62177)
2015 Kubota...
2004 Ford F-550 Flatbed Truck, VIN # 1FDAW56P24ED63182 (A65563)
2004 Ford F-550...
2021 Ford Econoline Box Van, VIN # 1FDWE3FN3MDC22817 (A65563)
2021 Ford...
