JD 2155 hydrolics, steering and three point hitch are slow after oil gets warm
   / JD 2155 hydrolics, steering and three point hitch are slow after oil gets warm #1
chipperoyea
Zachary, La
JD2155
My 2155 JD steering and three point hitch don't operate correctly after tractor gets warm.Could it be screen and/or filters?
   / JD 2155 hydrolics, steering and three point hitch are slow after oil gets warm #2
:welcome: to TBN
What is the history of the screen and filters? Hours since change would help answer your question.
   / JD 2155 hydrolics, steering and three point hitch are slow after oil gets warm #3
:welcome:
To the forum from Northwest Alabama. Does it operate correctly before the tractor gets warm?
   / JD 2155 hydrolics, steering and three point hitch are slow after oil gets warm #4
:welcome:
I would suggest to change hyd filter & check/clean sump screen. Then check stand-by pressure which should be 2250 psi. Is tractor equipped with hyd ind pto &/or hyd reverser/hi-lo?????? The afore mentioned options have supply tubes that could be leaking.
Don't know tractor belongs to friend, but do pLan to change all filters and clean screen as well. That seems to be the general consenses
1990 International 8300 Vacuum Truck (A47384)
1990 International...
2018 Chevrolet Tahoe 4x4 SUV (A50324)
2018 Chevrolet...
OKLAHOMA JOE'S CHARCOAL GRILL (A51244)
OKLAHOMA JOE'S...
2006 TOYOTA Highlander SUV (A50324)
2006 TOYOTA...
MAH QUICK ATTACH MAST W/ 48" FORKS (A51242)
MAH QUICK ATTACH...
Kubota RTV1100CR9 (A47384)
Kubota RTV1100CR9...
