JD 2155 hydrolics, steering and three point hitch are slow after oil gets warm
   / JD 2155 hydrolics, steering and three point hitch are slow after oil gets warm #1
chipperoyea
Zachary, La
JD2155
My 2155 JD steering and three point hitch don't operate correctly after tractor gets warm.Could it be screen and/or filters?
   / JD 2155 hydrolics, steering and three point hitch are slow after oil gets warm #2
:welcome: to TBN
What is the history of the screen and filters? Hours since change would help answer your question.
   / JD 2155 hydrolics, steering and three point hitch are slow after oil gets warm #3
:welcome:
To the forum from Northwest Alabama. Does it operate correctly before the tractor gets warm?
   / JD 2155 hydrolics, steering and three point hitch are slow after oil gets warm #4
:welcome:
I would suggest to change hyd filter & check/clean sump screen. Then check stand-by pressure which should be 2250 psi. Is tractor equipped with hyd ind pto &/or hyd reverser/hi-lo?????? The afore mentioned options have supply tubes that could be leaking.
Don't know tractor belongs to friend, but do pLan to change all filters and clean screen as well. That seems to be the general consenses
Bale Ring (A50515)
Bale Ring (A50515)
Agro Trend 7' 3PT Snow Blower (A52349)
Agro Trend 7' 3PT...
PALLET OF WALL PACKS (A51244)
PALLET OF WALL...
SET OF HOMEMADE FORKS (A51243)
SET OF HOMEMADE...
NEW HOLLAND L180 SOLID TIRE SKID STEER (A51242)
NEW HOLLAND L180...
