:welcome:
I would suggest to change hyd filter & check/clean sump screen. Then check stand-by pressure which should be 2250 psi. Is tractor equipped with hyd ind pto &/or hyd reverser/hi-lo?????? The afore mentioned options have supply tubes that could be leaking.
/ JD 2155 hydrolics, steering and three point hitch are slow after oil gets warm
