JD 2150 problem
/ JD 2150 problem #1
bagoat08
I have a JD 2150 with a Hydraulic problem.
We have replace the oil pump in the transmission (the pump was bad) about a month ago and we replace the Hydraulic oil, filter and cleaned the screen. Work good for a few weeks. Now the tractor has PS some of the time and the lift is real slow in raising. The lift does not leak down when parked. I use this tractor on weekends and it seems that the longer it sits the worse this problem becomes... The front pump is working.
What should we check?
Any help is appreciate...
/ JD 2150 problem #2
Does the lift chater a good bit when you let it up.
Vegetable Sprayer (A60462)
Vegetable Sprayer...
New/Unused SD Lanch Mobile Crusher (A61166)
New/Unused SD...
2026 Steel Pines Cargo 7x16 Enclosed Trailer, VIN#7FWBE1629T1037830 (A61166)
2026 Steel Pines...
New/Unused 7ft Fork Extension (A61166)
New/Unused 7ft...
UNUSED CFG INDUSTRIAL MX15RX MINI EXCAVATOR (A62130)
UNUSED CFG...
UNUSED JCT 72" HYD TILLER (A62131)
UNUSED JCT 72" HYD...
