JD 2150 problem
/ JD 2150 problem #1
bagoat08
I have a JD 2150 with a Hydraulic problem.
We have replace the oil pump in the transmission (the pump was bad) about a month ago and we replace the Hydraulic oil, filter and cleaned the screen. Work good for a few weeks. Now the tractor has PS some of the time and the lift is real slow in raising. The lift does not leak down when parked. I use this tractor on weekends and it seems that the longer it sits the worse this problem becomes... The front pump is working.
What should we check?
Any help is appreciate...
/ JD 2150 problem #2
Does the lift chater a good bit when you let it up.
2018 Nissan Rogue SUV (A61569)
2018 Nissan Rogue...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
(INOP) VOGELE VISION 5200-2 ASPHALT PAVER (A62130)
(INOP) VOGELE...
2015 HINO 195 16FT BOX TRUCK (A59905)
2015 HINO 195 16FT...
10ft Cattle Panels (A64047)
10ft Cattle Panels...
UNUSED (2) 3" HYD CYLINDERS (A62130)
UNUSED (2) 3" HYD...
